Edit Object display question
Why is it that certain geometry don't change color even after I apply a color change through the edit object display menus? The layer is not locked, and it's very annoying. Also, what is the difference between edit object display, and "Assign feature color" in the part navigator? Thanks, first post!
RE: Edit Object display question
John Joyce
Manufacturing Engineer
Senior Aerospace CT
Edit Object display - It is used to change the display properties for selected objects like faces, curves, etc..
Assign Feature color - Set the color for the faces which all are created by that feature.
SelvarajC
NX Automation Engineer
