Pile - Raft Load Sharing Ratio
I am conducting some research on piled raft load sharing ratio between piles and rafts. Do you have any idea if there is an easy way to get the loads carried by piles and loads carried by soil???
I am using embedded pile to model the piles with hardening soil.
RE: Pile - Raft Load Sharing Ratio
For a conventional pile cap over pile (doweled connection), Fellenius would say there is no bearing pressure on the bottom of the pile cap, except near pile failure.
Poulos has written theoretical work, as well as case studies on disconnected piles below mat foundations.
