Telltale Hole Location API 650 Tank
Does anyone know of a minimum distance for a telltale hole to the edge of a repad for API 650 tanks?
All I can see in the code is along the horizontal center line. There has to be a minimum edge distance though. There's no way you can't put them right on the edge of the repad.
RE: Telltale Hole Location API 650 Tank
For round repads, I usually split the distance from the neck weld to the edge of the plate, as shown in API 653 figure 9.14.
