Getting error code "100" from wild heerbrugg dmi5s distomat
Hello
I am getting an error code "100" reading from my wild heerbrugg DI5S distomat, can anybody tell me what this
means and maybe how to fix it.
Jerome
RE: Getting error code "100" from wild heerbrugg dmi5s distomat
Hello
Thanks for the response,the manufacturer informed me that they do support the device any longer.
Jerome
I don't know which fault the code signifies, but the usual fault that I used to get was either too weak or too strong return signal, the remedy was gently tapping the top of the unit to free the cascade filters. That was on DI3S though.
Cheers,
Chris
Thanks for your advice but I was able to eliminate the code error by supplying the correct voltage to the distance measuring instrument,
the correct voltage was 12 volts dc.
Jerome
