what is the axial and radial clearances between pump impeller hub and balance disk ?
RE: what is the axial and radial clearances between pump impeller hub and balance disk ?
Based on your very polite question, I would suggest you ask the pump manufacturer.
Agree, it is specific to the pump and only the pump manufacturer will be able to answer the question.
