surface construction preferences
Hi all
Quick question regarding the constructions options for freeform surfaces. There are two options in Preferences --> Modelling --> Freeform --> Freeform Construction Result. These are Plane or B surface. What is the difference/s between the two, which is the best to use and why?
many thanks in advance
Si
Si
Best regards
Simon
NX7.5 NX8.5 NX9 NX10
NX Consultant
www.team-eng.com
RE: surface construction preferences
A plane is , counted in "megabytes", very small in comparison to a b-surface.
The planar surface is "as exact as possible" whilst a b-surface always (?) has the modeling distance tolerance.
So, if your intention is to deform something, it must be b-surface.
But, the modern deform features such as X-Form, I-Form , Match edge etc WILL convert whatever input faces to b-surface before you get to touch the dialog.
( The older Global Shaping did /do not do this why i used to extract, into b-surfaces, the faces before using it. Haven't used the Global Shaping feature recently so i don't know if it is the same today.)
I would go Planar until you realize that you need the b-surfaces for some specific reason. ( Styling/ pole manipulation is such a reason.)
Tomas
Best regards
Simon
NX Consultant
www.team-eng.com
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
