This journal give correct output in NATIVE but Incorrect output in NX Manager (TC)
Hi All
can anyone explain why
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module scan_assembly_toplevel_components_and_report_loadstatus
Dim s As Session = Session.GetSession
Dim ufs As UFSession = UFSession.GetUFSession
Dim dispPart As Part = s.Parts.Work
Dim lw As ListingWindow = s.ListingWindow
Sub Main()
Dim selectedComps(-1) As Assemblies.Component
Dim fmComps(-1) As Assemblies.Component
Dim n_comps As Integer = 0
Dim n1,n2 As Integer
Dim thisName As String
Dim rd_cnt As Integer
Dim counter As Integer = -1
Dim root As Component = dispPart.ComponentAssembly.RootComponent
Dim toplvlComps As Component() = root.GetChildren()
ufs.Ui.ExitListingWindow() ' Clear and close the window
lw.Open()
lw.WriteLine("")
lw.WriteLine("============================================================")
lw.WriteLine(" Program ... START ...")
lw.WriteLine("")
lw.CloseWindow()
n_comps = toplvlComps.Length
lw.WriteLine("Top level components number = " & n_comps.ToString)
lw.WriteLine("")
lw.CloseWindow()
counter = -1
If (n_comps) > 0 Then
For Each thisComp As Component In toplvlComps
If ufs.Part.IsLoaded(thisComp.DisplayName) = 0 Then
lw.WriteLine("nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn")
lw.WriteLine(thisComp.DisplayName & " ==> Not loaded")
counter += 1
ReDim Preserve fmComps(counter)
fmComps(counter) = thisComp
End If
If ufs.Part.IsLoaded(thisComp.DisplayName) = 1 Then
lw.WriteLine("ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff")
lw.WriteLine(thisComp.DisplayName & " ==> Fully loaded")
End If
If ufs.Part.IsLoaded(thisComp.DisplayName) = 2 Then
lw.WriteLine("pppppppppppppppppppppppppppppppppppppppppppppppppppppppppppp")
lw.WriteLine(thisComp.DisplayName & " ==> Partially loaded")
End If
Next
Else
Exit Sub
End If
lw.WriteLine("")
lw.WriteLine("Number of not loaded components = " & (counter+1).ToString)
lw.WriteLine("")
lw.CloseWindow()
For n1=0 To counter
If fmComps(n1) Is Nothing Then Continue For
thisName = fmComps(n1).DisplayName
rd_cnt = -1
For n2=n1 To counter
If fmComps(n2) Is Nothing Then Continue For
If fmComps(n2).DisplayName = thisName Then
rd_cnt += 1
ReDim Preserve selectedComps(rd_cnt)
selectedComps(rd_cnt) = fmComps(n2)
fmComps(n2) = Nothing
End If
Next
lw.WriteLine("x" & (rd_cnt+1).ToString & " " & thisName & " ==> Not loaded")
lw.WriteLine("------------------------------------------------------------")
lw.CloseWindow()
Next
MsgBox("Replace Components" & vbCrLf & " DONE" _
& vbCrLf & "Elbaz Haviv Feb 2016" _
& vbCrLf & "See Information Window")
lw.WriteLine("")
lw.WriteLine(" Program ... END ...")
lw.WriteLine("")
lw.CloseWindow()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
Thanks in advanced
RE: This journal give correct output in NATIVE but Incorrect output in NX Manager (TC)
More info
I run the journal in the same platform one time in NATIVE mode
and one time in NX Manager (TC)
and also the same assembly
THANKS
I think the difference between native and TC lies in this line of code:
CODE
According to the help file, {comp}.DisplayName will "Return the displayable name of the prototype part". In native NX, the displayable name will be the same as the part name; in TC it probably is not. When a part is imported to TC it gets a "unique identifier" assigned to it that is used as the part name in the database; you also get to assign a name to the part, such as 12345/A, but this is only an alias for the sake of "human convenience". If, in TC, the .DisplayName refers to the name that you assigned to it rather than the actual part name, it may be that NX can't find that part in session because the names don't match.
Try running the following code on the same assembly in both native and TC. If you get the same results with both runs, then my theory is invalid and we should move on...
CODE
Option Strict Off Imports System Imports NXOpen Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() If IsNothing(theSession.Parts.BaseWork) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim root As Assemblies.Component = theSession.Parts.Display.ComponentAssembly.RootComponent Dim toplvlComps As Assemblies.Component() = root.GetChildren() For Each tempComp As Assemblies.Component In toplvlComps lw.WriteLine("Display name: " & tempComp.DisplayName) lw.WriteLine("Part Leaf name: " & tempComp.Prototype.OwningPart.Leaf) lw.WriteLine("") Next lw.Close() End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End Modulewww.nxjournaling.com
I'm very thank you
Next sunday I'l be in work and I'l test your code.
note that the help for ufs.Part.IsLoaded say these returns
0 = not loaded
1 = fully loaded
2 = Partially loaded
and any other = error
logicaly if TC have invalid part name will throw an error ?
and note also that TC output is not loaded for all components
Thank you again
Does NX search through all the parts in every folder on your computer/network to determine the file doesn't really exist?
I doubt it.
More likely, it can't find the part in session, so it returns "not loaded".
It sounds strong !!!
THANKS
Running the journal in the same platform on the same assembly
one time in tc and one time in native.
Give the same exception as follows:
NullReference exception on this line
And until this exception the output is as follows:
In Native is
Display name: xxxxxxx-yyy_-
Part Leaf name: xxxxxxx-yyy_-
Display name: 1-1469492-3_B
Part Leaf name: 1-1469492-3_B
Display name: 1-1469492-1_B
Part Leaf name: 1-1469492-1_B
Display name: MS24693C3_abc
In TC is
Display name: xxxxxxx-yyy/-
Part Leaf name: xxxxxxx-yyy/-
Display name: 1-1469492-3/B
Part Leaf name: 1-1469492-3/B
Display name: 1-1469492-1/B
Part Leaf name: 1-1469492-1/B
Display name: MS24693C3/abc
Note that MS24693C3_abc is a hardware family member component.
Thanks in advanced
CODE
ufs.Part.IsLoaded(thisComp.DisplayName) ufs.Part.IsLoaded(thisComp.Name)www.nxjournaling.com
Hi
For native the output is the same as previuos post
and for TC is the same except for this line
previuos output ==> Display name: MS24693C3/abc
new output ==> Display name: MS24693C3
Thank you for this try
My code (above) with the change "ufs.Part.IsLoaded(thisComp.Name)"
gives changed output for native and TC but not correct for native and not for TC.
Note:
In my works we have 4 apps that I use as follows
2 graphics apps
1 nx native executed from a batch file to work in native with windows files
1 nx manger executed from a batch file to work on nx manager with
a web file enviroment called web nx manager.
after I finish the design and drawings I do a pre-release that transform the
drawing to othere file enviroment called TC web.
I do not know how all these configured.
So I let it as is and I ignor it until I know more about the configuration.
I'm very thank you for your eforts
