Problem with Contact in Static Structural
Hi, I'm a 3rd Year Student and I'm trying to model a prototype joint in ANSYS, however I am having lots of problems getting it to solve. The joint consists of a wire passing through a hole in a block, then it is bent around to stop it coming back through (please see attached image). I'm then applying a displacement to the end face of the wire, to see the stresses and deformation.
I was getting a lot of problems with penetration, however I think I solved that problem by switching on Shared Topology to achieve conformal meshing, however the model now won't solve. I have tried adjusting all of the contact options, but nothing seems to work.
Any help would be massively appreciated, thank you!
RE: Problem with Contact in Static Structural
