Anchor Guardrail to Composite Deck
Does anyone have details or suggestions on how to anchor steel guardrail to composite deck?
I've obtained blocking details from two different companies. I'm looking for options.
Thank you!
Thank you!
RE: Anchor Guardrail to Composite Deck
In very general terms:
Attach to an edge angle or anchor into the concrete with shallow anchors if those things will work. Otherwise, consider through bolting to a plate, angle, or tube set beneath the deck.
I'm referring to the plasticized exterior 5/4 wood look-alike. Please see attached.
Does that change the picture?
I would be extending the post down to the meat below the decking. Or at a bare minimum, extending the connection to some meat below and treat the decking as blocking only.
The solid blocking board below the decking
The 4x through bolts and nuts holding the railing post steel mounts though the decking through that blocking board.
The two sideboards around the blocking board
The proper mounting (not end nails!) tieing the two sideboards to the outer deck beams.
So, no, according to this detail sheet, the composite decking alone cannot be used the mount the railing steel post foundations to the deck.
