Export JT or 3D NX model for Augmented Reality Applications
I am looking at if we have a connector which could export JT or 3D NX models for Augmented Reality(AR) Applications.
Assuming a JT file, does the export of 3D model alone sufficient(a monolithic JT) for Augmented Reality needs or the relevant markups on the JT also needs to be exported? In the same parlance, how do we map the physical object Markups (markerless markups) to the 3D model Design? Can it be associated with markups which we create on JT? Is wireframe model in the JT to be included?
Any available resources which explains about this process of reusing existing 3D CAD for augmenting needs is great help.
