ACI D.6.2.7 Shear Capacity Modification Factor
Per ACI 318-11, D.6.2.7, the cracked concrete modification factor = 1.2 may be used if
"a No. 4 bar or greater (is) between the anchor and the edge.."
There is no commentary and no specifics are given.
Just wondering if anyone has more info. on where the #4 (or greater) bar must be placed. Any requirements regarding position with respect to failure surface / assumed failure surface?
Any requirements for bar length / to what point the bar must extend? Any requirements to develop the bar / provide hooks at end of bar?
A sketch is provided for reference.
