Recip defect frequencies
I read a piece on aircraft engine vibrations that stated a misfiring engine produces high 1 1/2x vibration.
Then I read a document from a major recip engine manufacturer (not aircraft) which stated that misfire generates 1/2x vibration. It further stated that 1 1/2x and 2 1/2x vibrations were a normal part of combustion and couldn't be alleviated?
Why the difference?
Why the difference?
RE: Recip defect frequencies
Perhaps different arrangements (Flat-6; Inline-4; V8; etc.) exhibit different vibration responses to a misfire.
However the particular harmonics are amplified by the structures resonances, and acoustic resonance, so although the forcing at 0.5 is strongest, if there are no resonances at that frequency a higher harmonic may dominate. For instance on an automotive engine you'll see a lot of whatever order is around 300 Hz, as that's a typical crankshaft bending and torsional frequency.
1.5 and 2.5 order would be the dominant firing excitation for a 3 and 5 cylinder engine 4 stroke respectively. So it rather depends on what the engine is, it'd help to see the remarks in context.
Cheers
Greg Locock
http://www.cml-acatdealer.com/upload/day_151021/20...
MikeL.
Very helpful answer Greg and thanks Cat for that. If I didn't have it already, that would be very helpful. That is actually the document I was referring to in the second part.
Does it make any difference (in the discussion about the defect frequencies) with spark engines compared to diesel type?
Cheers
Greg Locock
