Repeat Regions Help Needed
I need to override some titles of parts that are released in a drawing BOM and I can't figure out the relation needed to do so. I tried creating a new parameter as shown below:
CODE -->
desc1 = " "
if exists("asm_mbr_partnumber")
     desc1 = &asm.mbr.nomenclature&asm.mbr.title1&asm.mbr.title2&asm.mbr.title3
endif
     if asm_mbr_partnumber == "1234"
        desc1 = "NEW DESCRIPTION"
     endif
endif
It seems to be failing due to the multiple strings added together. What is the correct syntax for this?
RE: Repeat Regions Help Needed
You have not added the strings together and the parser thinks it is one long variable.
try this: desc1 = &asm.mbr.nomenclature + &asm.mbr.title1 + &asm.mbr.title2 + &asm.mbr.title3
Ben Loosli
