Three defining face chain error
I create a face blend using three defining face chains.
My problem is that if I delete a feature before the face blend, even if it is not related to the face blend, UGNX wants to delete the face blend as well. It does not happen if I just use the two defining face chains.
This has happened to me on two different files. One a carbon canister and this current one, a resonator.
Has anyone encounter this problem? Any fix besides not using the 3 defining face chain option?
Thanks!
Thanks!
UGNX 9.0.2.5 MP1 - Windows 7 64bit
Productive Design Services
www.productivedesign.com
RE: Three defining face chain error
The work around I have with my previous resonator is using a sweep with two sections.
I kinda like the three face blend because it makes the model simple.
With my current UG version, if I delete the line or the distance measurement, UGNX would like to delete the face blend as well.
I will check with our IT guy if I can have UGNX updated to a more recent MP
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
