Feasible way to obtaining dehumidified air for performing dry-lay up for hydrotested pipe
Thanks For The Previous suggestions,
I am struggling to find a feasible way of getting dry air (Dehumidified) for performing Dry Lay-Up for Stainless Steel Piping.
Dry Lay-Up is performed in-order to attain the hydro-tested pipes free of remnant water and moisture.
Can anyone please help me to obtain dehumidified air with any method ?
RE: Feasible way to obtaining dehumidified air for performing dry-lay up for hydrotested pipe
This is very common equipment - I don't understand why you're having a problem find it.
You need to be below the dew point at the buried temperature of the pipe. You won't get that with hot humid air.
