Change the transparency of the selected part using a journal
I am new user and this is my first journal.
I'd like to have a button to set the translucency of the selected part to 70%. I have recorded the following journal, but it basically does it only for the part that was selected during the record procedure:
Could you please guide me on how I can change it so that it validates the variable component1 to the selected part instead of the part named "model3"?
Thanks in advance.
CODE -->
using System;
using NXOpen;
public class NXJournal
public static void Main(string[] args)
NXOpen.Session theSession = NXOpen.Session.GetSession();
NXOpen.Part workPart = theSession.Parts.Work;
NXOpen.Part displayPart = theSession.Parts.Display;
// Menu: Edit->Object Display...
NXOpen.Session.UndoMarkId markId1;
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Edit Object Display");
NXOpen.DisplayModification displayModification1;
displayModification1 = theSession.DisplayManager.NewDisplayModification();
displayModification1.ApplyToAllFaces = true;
displayModification1.ApplyToOwningParts = false;
displayModification1.NewTranslucency = 79;
NXOpen.DisplayableObject[] objects1 = new NXOpen.DisplayableObject[1];
NXOpen.Assemblies.Component component1 = (NXOpen.Assemblies.Component)workPart.ComponentAssembly.RootComponent.FindObject("COMPONENT model3 1");
objects1[0] = component1;
displayModification1.Apply(objects1);
displayModification1.Dispose();
// Menu: Tools->Journal->Stop Recording
public static int GetUnloadOption(string dummy) { return (int)NXOpen.Session.LibraryUnloadOption.Immediately; }
} Could you please guide me on how I can change it so that it validates the variable component1 to the selected part instead of the part named "model3"?
Thanks in advance.
RE: Change the transparency of the selected part using a journal
I suggest you get one of our samples, and adapt it.
If you search our knowledge base for Sample NX Open .NET Visual Basic program selected component you will see several that would make a good starting point.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpenUI Module changeColorOfPreSelectedFaces_v2 Dim theSession As Session = Session.GetSession() Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager Sub Main() '' The selectFaces method takes an NXobject array by reference Dim selectedObjectsArray() As NXObject Selectbody(selectedObjectsArray) '' Need to recast the face NXObjects to Displayable objects Dim faceArray(selectedObjectsArray.Length - 1) As DisplayableObject For i As Integer = 0 To selectedObjectsArray.Length - 1 faceArray(i) = CType(selectedObjectsArray(i), DisplayableObject) Next Dim changeBodytransluency As DisplayModification = theSession.DisplayManager.NewDisplayModification() With changeBodytransluency .ApplyToAllFaces = true ' .NewColor = newColorCode .NewTranslucency = 40 .Apply(faceArray) .Dispose() End With End Sub '' The following routine is from GTAC ' ---------------------------------------------- ' sub to select faces ' ---------------------------------------------- Sub Selectbody(ByRef selectedObjects As NXObject()) Dim ui As UI = NXOpen.UI.GetUI Dim message As String = "Select body" Dim title As String = "Selection" Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim keepHighlighted As Boolean = False Dim includeFeatures As Boolean = False Dim response As Selection.Response Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim selectionMask_array(1) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_component_subtype .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY End With With selectionMask_array(1) .Type = UFConstants.UF_solid_type .Subtype = 0 .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY End with response = ui.SelectionManager.SelectObjects(message, title, scope, _ selectionAction, includeFeatures, _ keepHighlighted, selectionMask_array, _ selectedObjects) If response = Selection.Response.Cancel Or response = Selection.Response.Back Then Return End If End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY End Function End ModuleWith best regards
Michael
