Air conditioned air for compressor suction
Dear all,
During last summer we have faced frequent issues of discharge Air temperature high in Rotary screw oil lubricated single stage air compressors(Rated Pressure 8 bar,500 CFM, 75 KW) because of summer heat.
Can we use air conditioned (cooling coil)dehumidified space to reduce suction air temperature which may also save energy use of compressor? Can we use dehumidified air for compressor suction?
Thanks in advance.
Thanks in advance.
RE: Air conditioned air for compressor suction
It is most likely that you can fix your problem by increasing oil flow much less expensively. Take a look at thread1036-183642: Wet Gas Screw compressor to see a pretty good discussion of temperature management in oil-flooded screws.
The arithmetic is a bit complex, but at least it is closed form and can be directly solved without iterations. You can find a version that works at thread391-294813: Heat of Compression with CO2 System (there is an attachment to the last post that has a corrected version of the calculations).
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
B.E.
You are judged not by what you know, but by what you can do.
You can keep the compressor room cooler by directly venting the hot exhaust air outside of the compressor room (depending on how cold you get in winter, it can be used for space heating during the winter season). Alternatively, if you have a process that requires hot water, many compressor manufacturers have the option to add a heat recovery system. If you have multiple units, you could even re-distribute the load.
zdas04's suggestion might be the most cost effective though.
Everything said here is valid, but essentially it is just about where in the sequence you remove heat from the air you're compressing to the ambient air.
Sure, your min discharge air temp won't fall below 10C higher than ambient for a simple fin fan cooler, but given that the OP hasn't actually given us any temperature figures we're all just spouting hot air.....
David Simpson, PE
All air compressors already include this in the package. The issue is that as ambient heat and humidity get past a certain point, you cannot fit a large enough cooler and fan into a reasonably sized packaged unit. Technically, the problem is trivial. Most customers buy on price, so compressor manufacturers have to design to price points.
A 500cfm compressor is a decent size compared to a space air conditioning unit so I think it will be difficult to get air temp down to anything worthwhile..
You mean to say lowering suction air temperature doesn't help?
"Can someone tell me whats wrong with an air cooled heat exchanger on the outlet air? Just one fan and no pumps or complex air conditioning system."
The issue is not with discharge air temperature. The issue is compressor trip due to high oil temperature.
There will be heat exchanger(just like car's radiator with a blower) which cools the oil which gets heated in the compression process. Because of the high ambient temperature in the summer, the heat exchange is not effective and the hot oil is recirculated back to screw raising the oil temperature.
Your OP stated "last summer we have faced frequent issues of discharge Air temperature high". Your latest post now says "The issue is not with discharge air temperature".
One is the opposite of the first and now you say the issue is actually the oil temperature (!)
So how about making the oil cooler a bit bigger?, or maybe cleaning the radiator? or adding a second one.
What were temperatures experienced. (Oil in, oil out, ambient air?) How big is your oil cooler?
David Simpson, PE
je suis charlie
je suis charlie
Take a look at the attachment to the last post in the second thread I linked above. Remember that you are only lowering the suction temp from 560R to maybe 530R. Not a huge change.
David Simpson, PE
Have you checked the air filters on the oil cooler radiators ? Partial plugging of these filters in high ambient temps can be enough to trip the high oil temp alarm.
Also have you talked to the manufacturer of the compressor , about adding another oil cooler ?
You do need to talk to the manufacturer, all we are doing here is guessing aided and abetted by the lack of information at your end. You do not even tell us who makes the compressor.
B.E.
The reason that interesting anecdote is totally irrelevant is that the 5 stage centrifugal better not be oil flooded, or ugly things are going to happen.
David Simpson, PE
