Catia VBA to Extract 2D line start & end point coordinates
I'm looking for catvba code that can put the coordinates of 2D line start-point & end-point into a variable.
I believe object class Curve2D is the way, using it's startpoint/endpoint properties. I do not know the code that will allow me to get the value of these properties into a variable. Looking for some coding help on this one. Thanks!
RE: Catia VBA to Extract 2D line start & end point coordinates
