Masonry Pier and Curtain Wall
I have a client who wants to open up an existing exterior wall as part of a renovation project. The opening is 10' wide into a new elevated sunroom. the loads at each end of the 10' opening are 4.2k. The property slope varies but max ht of a load bearing masonry pier/curtain wall is about 8'. What do you guys normally do to beef up the 4in brick curtain wall? All I can think to do is add CMU piers behind the curtain wall assuming there isn't one already there and attach blocking to the band to help transfer some of the load into the CMU and not all on the brick.
RE: Masonry Pier and Curtain Wall
You also might want to check the brick on its own. It may be able to support 4.2k.
