Cold Formed Steel Sheathed Shearwalls
Quick question. The AISI 213 Lateral Design Doc gives tabulated values for 1/2" Gyp sheathing. My architect wants 5/8" gypsum. Can i use the 1/2" values?
I know sheathed system capacity is all about fastener slip in the sheathing, so i could see the added gyp thickness affecting these values. My instinct is that the capacity would be greater with thicker Gyp, just wanted to see what others thoughts might be.
THanks,
THanks,
RE: Cold Formed Steel Sheathed Shearwalls
