Patterned Dwg Formats, NX9
Will these translate into DXF format ok?
I tried the Symbol method for building one and tested it. It didn't translate at all so that ones checked off the list as an option.
TIA
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
RE: Patterned Dwg Formats, NX9
Since you are using NX 9, I'd suggest that you take advantage of the "borders and zones" and "drawing titleblock" tools.
www.nxjournaling.com
Ok.. took a quick look and really like that the formats snap to the sheet size changes. That's excellent.
But, can the title block be made to follow it? That I didn't have success with.
I also figure special text like units and projection symbols wouldn't either?
TIA
Dave
NX9, Win 7 Pro SP1
The title block can follow in NX10 (it was added to allow an associative origin).
For the units & projection symbol, I would suggest using the automated text.
I made a series of videos for our Vimeo site a year ago about drawing templates, I can't remember which one covered the automated text:
https://vimeo.com/album/3065578/video/101692825
or
https://vimeo.com/album/3065578/video/100179684
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
Yes, using patterns in NX9, the pattern does translate into DXF.
Make use of the variable UGII_PATDIR
NX 9.0.3.4
NX 10.0.3.5 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
