Macro to Save, Print, and Close file
I'm looking to see (before I jump on in) if there is a way to have a macro in EXCEL save a file, print the file, and then close the file. Is this something that can be done through a macro?
TIA!
~Boottmills
RE: Macro to Save, Print, and Close file
What application?
Skip,
glassesJust traded in my OLD subtlety...
for a NUance!tongue
EXCEL...Sorry...just edited it :)
~Boottmills
Have you tried recording a macro?
Skip,
for a NUance!tongue
Save
Link
Print
Link
Close
Link
String those together, try one at a time to get the hang of it and make sure you are getting the desired effect. By default the printout method simply uses the currently selected printer, so depending on what printer you used last it will just print to that (i.e. physical printer or maybe PDF etc) unless you use the ActivePrinter variant. You can always use a userform to select between different printers if desired.
Are you trying to save, print, and close the Excel workbook or another file (such as a text file)?
