.f06 file big size issue [MSC NASTRAN] (how to split)
Dear All
Greetings
How to manage / split output file .f06 into multiple to reduce its huge size because of large structures problems and non-linear solutions?
[Most available text-editor are not able to open such big files, that's why need to customize the output to reduce file size]
Advance thanks for your help
Abi
RE: .f06 file big size issue [MSC NASTRAN] (how to split)
How many GBs of f06 files are they?
Spaceship!!
Aerospace Engineer, M.Sc. / Aircraft Stress Engineer
The size is going upto 20GB and more :(
for info: using PUCK criteria with 400 solution
Thanks a lot @dmapguru. It worked.
I use (and love) UltraEdit for this purpose. Not free, but fairly inexpensive. Free trial for 30 days is available. I like the Nastran syntax highlighting.
________________________
FEMAP v11.1.0
MSC Nastran v2013
Hi Abi, could you find out why your .f06 file is too large?
If you are unable to open and read, then better to run just a small part of your FEM just to check.
Try to focus on lines which have a lot of repetitions.
Example: if you have solid element (CTETRA10, HEXA8 etc.) then you may recieve message in .f06 that DOP in rotations are not defined, it look like this:
G R I D P O I N T S I N G U L A R I T Y T A B L E
0 POINT TYPE FAILED STIFFNESS OLD USET NEW USET
ID DIRECTION RATIO EXCLUSIVE UNION EXCLUSIVE UNION
729192 G 6 0.00E+00 BF F SB S *
729193 G 4 0.00E+00 BF F SB S *
729193 G 5 0.00E+00 BF F SB S *
729193 G 6 0.00E+00 BF F SB S *
729194 G 4 0.00E+00 BF F SB S *
729194 G 5 0.00E+00 BF F SB S *
etc.
This you can simply suppress by adding of parameter:
PARAM, PRGPST, NO
There many options how to reduce .f06, but it is better to know what...
Hope this helps, Jan
