NX10 and windows taskbar
thread561-386981: NX9 and windows taskbar
Same situation in NX10 (10.0.3 MP01). NX9 and NX10 ovelaps taskbar and can not be displayed.
NX 9.0.3.3
RE: NX10 and windows taskbar
The taskbar ? NX?
Can you provide an image ?
Tomas
NX 9.0.3.3
If you're having issues with a maximized NX window covering the taskbar, then don't maximize the NX window. Size the NX window so that it is essentially maximized and allow for a small gap where the taskbar resides so that when you hover over it, it will appear over the NX window as it should. Windows should restore the NX window size and position permanently after that.
Has happened to me for a few years on Win7 - I've just been too lazy to report it to Siemens. If you don't have success, then I'd be getting in contact with Siemens and have them see if they find the same problem. From my experience, it didn't happen immediately - it took a day or more before the taskbar just wouldn't appear above the NX window.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
