barrier fluid compatible with EPDM
Does anyone know of a good barrier fluid to use that's compatible EPDM elastomers and at -40C temp. Pumpage is Ethanol. Plan 52.
RE: barrier fluid compatible with EPDM
Silicone oil, though water/glycol or water/alcohol or even straight ethanol would also work...but might contaminate your pumped fluid.
