How to calculate the maximum acceleration that a tractor can achieve
3
Generally, agricultural tractors have a speed limit of 40 Km/hr. Is there a way to calculate the maximum acceleration that tractors can reach keeping the maximum speed limit into consideration!!
RE: How to calculate the maximum acceleration that a tractor can achieve
a=T/mr
Knowledge of speed limit unnecessary.
Popping the clutch from a standstill with the engine at the governed limit will momentarily make it accelerate a lot faster than rated torque would indicate. Might even wheelie.
(I learned to drive on a tractor ...)
Highest acceleration would be a 40->0 stop in a short distance. Like within in the length of the vehicle.
Steve
Or ramming it into a solid metal wall... acceleration will be whatever you can get from deformation of a metal tractor @ 40km/hr.
Dan - Owner
http://www.Hi-TecDesigns.com
OK, so what is the purpose of your OP?
The tractor can accelerate a towed load pretty smartly if you start with a lot of slack in the sturdy chain connecting them.
Mike Halloran
Pembroke Pines, FL, USA
Max acceleration of 32 ft/sec^2 when driven off a cliff. sadeyes
That's Deceleration .
B.E.
You are judged not by what you know, but by what you can do.
Acceleration is normally a vector. Doesn't have a sign pipe
Steve
Tell that to the tractor that came to a sudden stop wink
Dan - Owner
F = m*a
Figure out how much force (torque) the engine produces, Figure out the mass you're accelerating, and then the question remains basic as you solve for acceleration.
Don't forget to know the moment of inertia of drivetrain, how much friction you're dealing with, wind drag, and the fact that you would need a fictional transmission.
Another good way to do it is put an accelerometer in the tractor, and then accelerate as fast as you can.
The first option I have you is somewhat like how an engineer would solve it.
The second answer is what the engineering technician would do when the engineer wants the actual answer ;p
Original poster is nowhere to be found.
I think he got sucked into a black hole. Calculate that acceleration.
Now you have me wondering what the size of the singularity is for an Earth-mass... does that even make sense, since an Earth-mass wouldn't, by itself, sink into a singularity?
Dan - Owner
It wouldn't turn into a singularity on its own, but it's theoretically possible to have a black hole with Earth mass. The Schwarzschild radius is admittedly small, about 88 mm. If we allow a reasonable distance, say, 30 ft, it drops down to 7.1825*10^14 g's
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
So at earth radius it's 1g?
je suis charlie
What distance would the event horizon be for such a singularity? My first guess is there wouldn't be one since there's not enough mass...
Dan - Owner
Someone's figures don't add up. Going from 1 g at 6378.1 km to a radius of 0.00914 km (30'), I get 697,8222 = 0.486 E12 g not 7.18 E14.
I get 238 mm radius for 7.18 E14 g.
je suis charlie
