Fully load component via journal
hello all, im new at journaling but could anyone help me on this one:
cowski snippet(thanks for it):
CODE -->
Dim thePart As Part = theComponent.Prototype.OwningPart
Try
    If thePart.IsFullyLoaded Then
        'component is fully loaded
    Else
        'component is partially loaded
    End If
Catch ex As NullReferenceException
    'component is not loaded
End Try
could anyone help me on how can i load the component if it isn't fully loaded ?
Thanks in advance
NX8.5 - NX9 User
RE: Fully load component via journal
Search for "Sample NX Open .NET Visual Basic program : open displayed assembly fully" in the GTAC Library.
Thank you i will search and then post my result.
NX8.5 - NX9 User
Well ive tryed the function, worked fine, but how can i open the "partial loaded" too ?
NX8.5 - NX9 User
If you have a reference to a partially opened component, you can fully load it with:
CODE
{theComp}.Prototype.OwningPart.LoadThisPartFully()
The part object also has a .LoadFully method that may be handy depending on your needs.
www.nxjournaling.com
im not seeing how im going to do it to be honest xD but i will try and post the result
NX8.5 - NX9 User
