Drawing updated, but red status in bottom left side shows "Out of Date"
Hello all.
I'm working in a single part that have a drawing completely updated, but this status red line on bottom left side.
I've already updated each view alone and all views together. Tried to update the hole sheet by select the sheet on navigator panel and tried to update the hole drawing by selecting it and choosing UPDATE in pull-down menu too.
Every information on screen indicates that the drawing is up-to-date, but the red line still showing Out of Date......
What more can I do to solve this?
There is some place that shows what exactly is Out of Date?
I'm using NX 9.0.3.4 MP6 here.
Thanks in advance.
Thanks in advance.
Gerson Fioravanti Junior
Mechanical Production Engineer
RE: Drawing updated, but red status in bottom left side shows "Out of Date"
What version of NX are you on?
I'm not doing a drawing from an assembly.. it's a single part file, so it's fully loaded.
I didn't even found this option to force full load.
This drawing was fine hours ago, but I've made some changes on it and then it started this issue.
The change was that I've created a sketch in a view, then I deleted that sketch. Just this...
https://community.plm.automation.siemens.com/t5/NX...
Short version: contact GTAC if it reports view is out of date and you can find no reason why.
www.nxjournaling.com
I was have the same problem see
http://www.eng-tips.com/viewthread.cfm?qid=399394
Thanks for your answers. I've checked them but none of them helped me, including GTAC (I don't have a user there and the guy that talked to me on the phone told me that a guy will contact me but this never happened).
But, I finally solved my problem doing a reverse check on what I did in drawing before the problem appear.
So I found that the problem was related to "Active Sketch View" feature. The curiosity here is that the sketch of one view was making other view to be out-of-date.
As I said before, this information are not explicit on screen, so, I just could see the problem after making that sketch active again. After activating it the other view becomes out-of-date, showing the clock icon behinds it. So, I updated the view, then quit sketch and just after that the Out-of-Date status disappeared on bottom left side.
I know this has happened to me, but I really could not remember what I did to solve the issue.
