Geometric Non linear Structures
Hi Forum Members,
I am designing a large span portal and after applying loads the portal is deflecting a lot. Is there any guidelines in any International code or standard, which says about a limit (Deflection) beyond which it becomes non linear behavior. I am bit confuse on this concept and large deflections and rotations will also give rise to wind dynamic loading.
Please suggest
RE: Geometric Non linear Structures
The codes don't provide any absolute diaplacement limitation but focus in a drift approach.
In this way, the drifts are limited. Moreover, the story indeces are calculated as a ratio between first and second order moments. Structural codes consider linear behaviour if the story index falls within the limits they define.
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Reifnorcement Design etc.
