Is Bulk CO2 Shipped Cryogenically To Minimize Tank Weight, Or For Some Other Reason?
Originally posted in the Railroad Equipment Engineering forum...but that seems to be a low traffic location, and probably the wrong forum considering the question...maybe here is a better fit?
My interest in railroads has been revived since I started volunteering aboard the retired / legacy steam ship SS Keewatin [www.sskeewatin.com], formerly an asset of the Great Lakes Steamship Service of the Canadian Pacific Railway...
Question: for bulk transportation of CO2 by rail [or large tanker truck] in North America, is liquid CO2 usually shipped cryogenically in heavily insulated tankers so the pressure rating and overall weight of the tank needn't be as high as if it were shipped at ambient temperature and higher pressure? My thought is that with the latter there would be less net loss en route due to expansion & blow-off, but that doesn't appear to be the way it's usually done.
For answers to the above, what reasoning is applied and/or what regulations prevail to dictate doing this one way or the other? My Internet search results to date have proven less than stellar...
Thanks!
Thanks!
CR
RE: Is Bulk CO2 Shipped Cryogenically To Minimize Tank Weight, Or For Some Other Reason?
OK, now, consider CO2 is 'fabricated" commercially by cryogenic separation from air .. so low pressure systems already exist in the "factories" that already provide the CO2 at very low pressure and very low temperatures. To ship it using room temperatures but high pressure systems, you'd have to heat the liquid CO2, then compress it. Easier to ship cold and keep cold.
And after all we ship liquid oxygen, nitrogen, argon, and hydrogen for some of the same reasons.
Another advantage is that the cryogenic sourced gases are much higher purity (dew points of -100F are common).
A.
Continuing research following my OP led me to a webpage that gave the particulars of storing liquid CO2 at ~300 psig [see https://kidde-fenwal.com/Media/Data%20Sheets/LP%20...]; despite its being a product promo, reading through this document made it clear how much more steel it would take to make a railroad tank car [and therefore how much higher the charges would be for returning the empties] to transport liquid CO2 at ambient temperatures [due to its much higher vapour pressure] instead of at zero Fahrenheit or colder, thick insulation still being much lighter than steel.
This being the case: the above-referenced document refers to instances where, in the event of failure of the AC-powered re-compressing and cooling machinery, how the refrigerant effect of flashing off excessive CO2 in the case of tank overpressure helps to limit further loss of CO2.
This makes me wonder: are or could refrigerated liquefied Class 1 gas rail cars, not having cooling machinery, be equipped with a cooling coil that routes the flashed gas down through a coil in the remaining liquid before venting said gas to atmosphere, in order to both take maximum advantage of said refrigeration effect of the flashed gas and minimize loss of remaining liquefied gas?
CR
It seems to me that I have seen tanks, probably tank cars too, with coils wrapped around the tank, under the insulation covering. These might be heating or cooling coils, and of course the tank car will then have an other skin of steel to cover and protect the insulation. I’ve never designed or built any tank cars, but I have been involved with them, in an engineering capacity, on several occasions. That’s why I suggested that you talk with some tank car manuf’ers. You might also add to my list of contacts, the people who make CO2, how do they ship their product, any rail shipment?
Also, thanks, dhengr, for the additional info [and just to let the rest of you know, dhengr was the only respondent to reply to the OP on this topic in the Railroad Equipment Engineering forum].
CR
A.
True, dry ice will form...but would it not impinge on the walls, absorb heat, and sublimate? Especially if the dry ice generation rate is not crazy excessive...
CR
I haven't looked up densities, but it wouldn't surprise me if the liquid was denser.
This is the part I don't get; obviously the heat of vaporization has been supplied to transform the liquid to gas, but in the scenario under consideration the gas is still at ~ 300 psig, so to my view expansion of same to atmospheric pressure will cause a further drop in temperature below the saturated pressure/temperature within the tank, meaning that at the very least the gas should become somewhat superheated by absorbing thermal energy from within the tank before escaping to atmosphere.
The refrigerating effect might not be huge; but 'uneconomical'? The equipment that would be used to accomplish the stated objective borders on the primitive, and I would not expect it to cost so an exorbitant amount as to preclude the possibility from being considered, which was precisely the reason for the OP...
CR
In theory yes that cold temperature could be used to cool a liquid which then passes into the tank via a coil, but the power to run the pump and weight of the cooling system is probably more than it would take to simply add a small refidgeration unit, compared to the amount of cooling undertaken by the gas volume. Remember the purpose of transport is to transport the gas, not let it all leak out on the way there....
Earlier in this thread I wrote:
All I was inquiring about was using the endothermic effect of expanding gas to provide some cooling so as to possibly mitigate, not eliminate, the loss of CO2 during its transportation; chances could be that such a low-cost unit might be of value during the summer season when there would be increased heat transfer through the tank car insulation, all without the trouble of adding a refrigeration unit with its attendant capital, operating and maintenance costs.
CR
Kind of like using a cigarette lighter to try and heat up a tanker load. In theory possible, but practically negligible
CR
