SA-573 Gr.70 and SA-516 Gr.70 are they the same?
Guys,
From ASME Section II Part D I could not found SA-573 but when I see its UNS number which is K02701 also not available, however I SA-516 Gr.70 UNS number is K02700 and when I refer to both mechanical and chemical composition, they're practically similar.
My question is are these material equivalent? If yes what distinguish between these two materials i.e. cost, manufacturing availability, or others?
Thank you
Thank you
RE: SA-573 Gr.70 and SA-516 Gr.70 are they the same?
