When distributor between beds needed and when not?
Hello Everybody
I was wondering when a distributor between each bed is necessary and when not. Is there something like a rule of thumb by bed height or bed diameter or packing?
I have a De-Ethanizer with two bed but with out distributor between.
Rico
Rico
RE: When distributor between beds needed and when not?
"A liquid re-redistributor is required at the top of each packed bed. The liquid flow from a typical support plate is not sufficiently uniform to properly irrigate the next lower packed bed. The multi-beam type of packing support plate, which is widely used, tends to segregate the liquid downflow from a packed bed into a pair of parallel rows of liquid streams about 2-in. apart with a 10-in. space between adjacent pairs. Gas distributing sup port plates, likewise, do not give a sufficiently uniform liquid irrigation pattern, because gas riser locations take precedence in the design of such a plate."
"A liquid distributor is required at all locations in the tower where an external liquid stream is introduced"
"Packed bed heights typically vary from 20 ft to 30 ft [3]. Many times the location of manholes to provide access to the redistributor will determine the packed depth. Whenever more than 15 theoretical stages are required in one packed bed, good liquid distribution is critical."
(R.Strigle, "Packed Towers and Applications", Gulf publishing, 1994).
Dejan IVANOVIC
Process Engineer, MSChE
Thanks for your response. I do have a distributor on top of the upper bed but not between both beds. The only different between both beds is the type/size of packing.
However, I will have a look in the book you refer to.
I subscribe to the belief that redistribution should occur between each bed. The basic theory supports this requirement- i.e. as the liquid spreads out in a cone below each drip point, it will build up against the wall. Redistribution at a minimum is needed to put liquid loading evenly onto the surface of bed below. In some cases more elaborate collection and redistribution is used to mix the liquid into a homogeneous composition before redistribution.
Although the theory would make optimum bed depth a function of packing type and tower diameter, 20-30ft beds are common as EmmanuelTop has written.
I also believe you probably have some redistribution and are missing it.
best wishes,
SShep
Liquid migration to the wall appears to be favored by small-column
diameter-packing diameter ratios (for random packings) and can be
corrected by the use of side wipers or redistributors. Inhibition of lateral
dispersion can be caused by the geometry of certain types of
structured packing, according to Huber and Hiltbrunner (op. cit.).
With careful attention given to the five causes of maldistribution, it is
possible to design commercial packed columns for heights of 8 to 9 m
between redistributors
It also says that packed bed mass transfer eff is significantly affected by the distributor design.
I would investigate, document, and file it away for when it is actually causing a problem.
