works at 2500F adhesive
I'm looking for an adhesive to hold the wire in place. this adhesive has to be at 2500F , don't give off any gas, and has to cure fast. do you have any suggestions.
RE: works at 2500F adhesive
Welded clips.
Except few metals themselves retain strength at that high a temperature.
Screw it down with Ti mounts and screws or nuts.
we don't want to weld. that wire is wrapping the cylinder. we want to glue the wire
Check out ceramic adhesives.
thank you
