[NX 10.0] Advanced Simulation Results (Not Found Issue)
I have a simple problem of a steel bar with a fixed constraint at one end with a tensile load at the other end. I have meshed and applied loads etc. I can solve the model and no error messages are sent through, however the results won't load. I have done some scouring of this problem and found similar cases to do with the license and I think this maybe the case.
I opened the .f06 file in text editor and the following FATAL error was found:
*** USER FATAL MESSAGE 3060 (PREFACE)
- AUTHORIZATION ERROR ***
UNABLE TO OBTAIN LICENSES FOR NX Nastran Basic - NX Desktop (Bundle)
PLEASE REFER TO THE LOG FILE FOR ADDITIONAL DETAILS
1 * * * END OF JOB * * *
*** USER WARNING MESSAGE 1152 (XCLNUP)
SOME DBSETS IN THIS DATA BASE WERE NOT INITIALIZED COMPLETELY.
USER INFORMATION: THE DATA BASE CREATED IN THIS RUN IS TOO IMMATURE TO BE RESTARTED.
USER ACTION: DELETE THIS DATA BASE BEFORE STARTING YOUR NEXT RUN.
Could someone direct me with the solution to this problem?
Kieron.
RE: [NX 10.0] Advanced Simulation Results (Not Found Issue)
Bump, really need this issue sorting.
First place to start:
Quote (error message)
Things to look for:
Do you have the proper license? Is that license checked out to you and not someone else?
Any recent changes to the license server? etc, etc.
