Orient angles while rotating
I'm trying to set some views of I part I don't own in TCE so that I can take ISO snapshots. So I go to orient and try combinations of 30, 60, etc until I get the right orientation. Excuse the word, but this is F^&%$&ing dumb. Its 2016, why can't NX9 show me the current angle/position as I dynamically rotate the model so that when I am close enough I can just round off the numbers? Is there such a thing that I don't know about (probably, please tell me). I've never had to do rotations like this on every god forsaken model, I would just simply set up the orientations and then replace view. However The admins here have only created 1 iso and 1 trimetric view. 30 years of using 3D software and they don't have the inkling that maybe it would be useful to add a few more orientations.
with great gratitude, Thanks!
RE: Orient angles while rotating
Gateway- General- part- Add Dimetric Views
Then restart NX and again try RMB in the graphics - Replace the view
Is this as desired ?
Tomas
This will let you rotate the model about a particular axis by dragging a slider control.
www.nxjournaling.com
