Timber Rafters on a Flat roof
I have a series steel portal frames with a timber joist infill. The joists are built into the rafter webs. There is a layer of 18mm plywood screw fixed to the top of the timber joists to give me diaphragm action. There is a light weight metdeck roof above this and finished with a standing aluminium seam roof clad. The roof is very light weight.
The roof is practically flat at 2 degree pitch. After doing some calculations on BS 6399 Part 2 I don't appear to have any pressure wind forces on the roof, it's all suction. Does this seem correct?
I'm trying to design the timber rafters and I was just wondering could I adopt a permissible deflection limit of 0.004 or should I limit deflection to 0.003 times the span as 2 of my spans are 5m and 6m respectively and don't want to call up ridiculous timber sizes? I was hoping to call up 44x225 (grade C16) everywhere but I might be struggling to get this to work.
Any advice welcome.
John.
RE: Timber Rafters on a Flat roof
Uplift only on a flat roof sounds right.
Depending on the finishes you can get away with .004*span (L/240) for live load deflection and .0055*span (L/180) for total. If it's brittle finishes then I would be designing to .003*span (L/360) for live and .004*span (L/240) for total.
Thanks Layrod12.
John.
Sorry again jayrod12.
I'm getting 2.4kN/m2 of wind uplift in a localised corner of my flat roof. This seems extremely high, could this be possible, does this seem correct to you?
John.
Feels about right. Not sure what code you're under but right at the corner that doesn't seem too out of the ordinary. It's high, but it's a small area.
Thanks Jayrod12.
John.
