Flange Corrosion
Flange Corrosion
Please find the attachment and please provide your suggestion, whether the flange faces can be repaired by welding + in-situ machining or whether the flanges need to be replaced completely.
RE: Flange Corrosion
As for that big plate flange? That's on you. I wouldn't be comfortable with weld buildup on something that thin, you'll never get it flat again. Probably take more time than replacing the flange anyhow...
Hassan (Preservation)
