Chlorine Shock Dosing
Hello Guys,
I have an Electro-chlorination plant designed for continuous dosing. I want to take only small part of its production in order to do shock dosing for a separate pump chamber.
Practically what should I do? Do I need to add only different pump for this purpose? Do I need another Electro-chlorination plant with different design?
RE: Chlorine Shock Dosing
Would depend on the application and volume of chlorine needed versus the production capacity and storage, none of which is stated.
