Convert assembly to one single body
Is there away to condense an assembly (with 100s of components) down to one single body? Export>parasolid is not what I'm wanting.
Thank you,
Trent
Thank you,
Trent
NX 9.0.3.4
RE: Convert assembly to one single body
If you have advanced assemblies you can use the Simplify assembly function...That will create linked bodies from all your components and unites them...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Parasolid export/import will, as you know, remove all parameters.
File Export - Part can export the bodies you select in the assembly to a single part and keep the parameters.
If you do it in "older versions of NX" you need to make sure that all parts are fully loaded. Later versions ( NX10 ) will load the required files fully.
You will NOT get a single body, unless you unite the bodies into 1.
To do this the bodies must have contact with each other.
Tomas
