Seismic questions
Seismic questions
In Part 4 of OBC dealing with the foundation design for seismic load (4.1.8.16.(1)): The clause says that the foundation should be designed to resist the lateral load capacity of the SFRS, except that when the foundations are allowed to rock, the design forces for the foundation need not exceed those determined in Sentence 4.1.8.7.(1) using an RdRo equal to 2.0.
Questions
1) Should the calculated base shear be magnified when designing foundation
2) If so, what force do we magnify to?
3) What is definition of rocking for a foundation?
RE: Seismic questions
Yes, unless a correspondingly low RdRo was used for the rest of the building a well.
a) If no rocking, magnify to the capacity of the system which is often enormous.
b) If rocking, magnify to RdRo = 2.0
Typically, a rocking foundation is one that would stop absorbing seismic load prior to reaching a target seismic overturning demand. It would start literally overturning and, in the process, stop attracting subsequent seismic load. This is the only Canadian specific doc that I know of: Link
Here are some examples, according to KootK:
1) Shear wall on pad footing at grade-ish: rocking.
2) Shear wall on pile cap and piles that wouldn't easily rip out in tension: not-rocking.
3) Shear wall extending into subterranean levels: KootK says not rocking; other designers typically say rocking.
In material that I've read from other parts of the world, recommendations are made that one should actual determine at what load rocking would occur and design for that load with some safety margin. And that seems eminently reasonable to me. Complex, but reasonable. Not sure how we get away with less.
I wish. I moved back to Canada from the US in 2007 and, right out of the gate, screwed up royally with regards to this particular code clause. As such, it's etched into my memory pretty deep. On the plus side, if Calgary ever experiences an Armageddon-ish event of some kind, I know just what library elevator shaft I'll want to hunker down beside for shelter.
The problem is that it's completely impractical for conventional construction. On the other hand, it actually makes a lot of sense if you understand how the reduction factors and rest of the seismic code work. Holding the foundation to the capacity of the lateral system should be pretty fundamental.
The fact that there's nothing there that puts a hard force cap at RdRo=1 or maybe 1.3 on the design force is an oversight, though.
It also does a terrible job of defining what the 'foundation' actually includes. Sliding and geotechnical allowables are items that should really be specifically addressed and presumably wouldn't fall into this clause. They aren't actually excluded, though.
It's one of those clauses that I'm pretty sure exists in its current state because they don't have the manpower to come up with a better defined requirement, but there really has to be /something/ in the code because it's incredibly important. We have some really good seismic guys around the country, but there's a lot of things to cover in the code.
I think I saw some changes proposed in the draft NBCC 2015, but I don't remember the details and I don't think it solved much? I haven't got a copy of the published version yet, so if anyone does maybe they can fill us in.
Mike McCann, PE, SE (WA)
I am not sure I understand msquared comment though.
Rocking is such a bad measure for designing of the foundation, removed from ASIC as a load limit. You can almost make the foundation anything you want with how the code defines rocking.
