wooden fender of FPSO
Hello Gents.
would you please i need help for installation a new wooden fender of the FPSO the existing one is Eucalyptus plank – treated with xilamon protection but the supplier gave me two options
which one the best
the first one
Eucalyptus Gonocephala the spesification as following
Common Name(s): White gum
Scientific Name: Eucalyptus Gonocephala
Distribution: Grown on plantations in Tunisia and Mediterranean Countries
Average Dried Weight: 70 lbs/ft3 (1,120 kg/m3)
Specific Gravity (Basic, 12% MC): .83, .1.12
Janka Hardness: 3,310 lbf (14,710 N)
Modulus of Rupture: 22,010 lbf/in2 (151.8 MPa)
Elastic Modulus: 2,612,000 lbf/in2 (18.01 GPa)
Crushing Strength: 11,340 lbf/in2 (78.2 MPa)
Shrinkage: No data available
Color/Appearance: Color ranges of the tree trunk from white to light grey.
Grain/Texture: No data available.
Endgrain: No data available.
Rot Resistance: No data available.
Odor: No characteristic odor.
Allergies/Toxicity: Besides the standard health risks associated with any type of wood
the second one is
the specification as following
Eucalyptus Camaldulensis - Datasheet
Common Name(s): Red Gum Eucalyptus.
Scientific Name: Eucalyptus Camaldulensis.
Distribution: Grown on plantations in Tunisia and Mediterranean Countries.
Average Dried Weight: 53 lbs/ft3 (850 kg/m3).
Specific Gravity (Basic, 12% MC): ..60, .85
Janka Hardness: 1,420 lbf (6,330 N)
Modulus of Rupture: 17,110 lbf/in2 (118.0 MPa)
Elastic Modulus: 2,049,000 lbf/in2 (14.13 GPa)
Crushing Strength: 8,640 lbf/in2 (59.6 MPa)
Shrinkage: Radial: 8.2%, Tangential: 12.8%, Volumetric: 21.0%, T/R Ratio: 1.6
Color/Appearance: Color ranges from a lighter salmon pink to a darker brownish red.
Appearance has been likened to both Black Cherry and Honduran Mahogany. Color tends to deepen
with age.
Grain/Texture: Has a medium texture and small to medium sized open pores. The
grain tends to be straight and even. Also, since the wood is grown and pruned on a plantation, there
tends to be few knots or other abnormal grain patterns.
Endgrain: Diffuse-porous; medium pores arranged in diagonal rows; exclusively
solitary; tyloses occasionally present; growth rings indistinct; rays usually not visible without lens;
parenchyma vasicentric.
Rot Resistance: Mixed reports, with most sources rating the heartwood as
moderately durable in regard to decay resistance, though it is susceptible to insect attack.
dust, no further health reactions have been associated with Eucalysptus.
In terms of mechanical/physical characteristics, it has a very high shrinkage rate, and is likely to
experience a fair amount of seasonal movement. The wood is relatively hard, heavy, and strong,
regards
RE: wooden fender of FPSO
Where are you? That will help us. Creatures that eat piles like some waters, others not so much. Are you looking for strength? Wear resistance?
I'm used to treated timber piles here in U.S. For extreme wear, we use UHMWPE facings.
Thanks for your reply
I'm in Libya, i am working in off shore field on Floating production storage and offloading (FPSO)I know all the data for the first (WHITE GUM) option higher than the second (RED GUM). Because i haven't any experience for the wood part may some one has the knowledge about this subject to give me the advice about it which one better, also this wood will be immersed in the sea time to time .
thanks a lot
Sorry, I will have to pass on this since I don't know the environment. I did Navy jobs around the Pacific and they are starting to go with plastic fender piles with various types of internal reinforcement. But these are expensive.
yeor79 - Check on the "White Gum" information you have posted. Here is a list of over 700 Species of Eucalyptus. "Eucalyptus gonocephala" is not one of them. Also, a Google search on that scientific name gave no meaningful results.
There is plenty of information on the web about "Red Gum", Eucalyptus camaldulensis.
www.SlideRuleEra.net idea
www.VacuumTubeEra.net r2d2
