Naming option for PDF
Whenever I print a pdf file, it always create a file with user_filename.
I search the customer defaults and I can't find an option to remove the "user" on the filename.
Anybody knows?
Edit:
I am doing "export" "pdf" when creating the pdf file.
I found the option under plotting and set Entry 1 "part name" 2&3 are set to "blank" but the username is still in front of the pdf filename.
Not using TCE.
TIA!
UGNX 8 / 8.5 / 9 - Windows 7 64bit
Productive Design Services
www.productivedesign.com
Anybody knows?
Edit:
Not using TCE.
TIA!
RE: Naming option for PDF
www.nxjournaling.com
P.S. These settings are found here: File, Utilities, Customer Defaults, Gateway, Plotting, Job Name tab.
