Draft/Draft body
Draft/Draft body
This should be reasonably straight forward, but it's tools I rarely use in NX. Attached is a simple model that requires 5 degrees of draft on all faces. My question is, is it possible to add the draft to all faces as the model stands in it's current state in one go using NX7.5? I can apply it incrementally by adding draft at difference stages of the model construction (before the blends) but I'm struggling to add it afterwards.
many thanks in advance
Si :)
Si :)
RE: Draft/Draft body
Best regards
Simon
NX7.5 NX8.5 NX9 NX10
NX Consultant
www.team-eng.com
www.nxjournaling.com
No, just the customer asking if it could be done like that, I would have done the draft first too.
Cheers
Si
Best regards
Simon
NX Consultant
www.team-eng.com
