Journal to replace file attribute titles
Is there a way to use a VB journal to replace attribute titles? I have a journal already that will go through a directory of files and add, delete, etc. to file attributes, but if I need to change the titles of one or more of the attributes, I don't have a way to do this. Does anyone have a script that does such a thing?
RE: Journal to replace file attribute titles
Instead delete it and create a new one.
Everything references the attribute by it's name so this is appropriate.
Paul
Paul Turner
CAD & Process Engineer
Mastip Technology
Yes, that's possible. However, if any of the existing attributes are linked to notes, expressions, other attributes, etc, these links will be broken.
What version of NX are you using?
www.nxjournaling.com
