Make dwg file show in views
I have a 3d model file that is a component of the 2d drawing.
When I created the views, UGNX selected the 3d model when creating the view.
Now, when I create some points in the 2d drawing file (while in modelling mode), it does not show up on the views.
How can I make the points show up on the views?
TIA!
UGNX 8 / 8.5 / 9 - Windows 7 64bit
Productive Design Services
www.productivedesign.com
RE: Make dwg file show in views
If you need to add geometry to the drawing file that you want to show in the view, make sure that when you add a view (base view command) the drawing part file is chosen (it defaults to the master model file).
In the example above, you would want to select the 12345_-dwg.1 file before placing the view.
www.nxjournaling.com
Can you try make the points "model dependent"
Select the view, RMB - View dependent Edit, " convert view dependent to model dependent" ( something similar )
Save the drawing before you do this in case it's wrong.
Tomas
If the geometry that you are adding is simple, one method would be creating a drafting sketch on the drawing view.
If the geometry is more complex or you need it to show up in multiple views, then a different method would be better...
@Cowski, I make drawings a couple of times a year and I forgot about this. Did not notice when creating the views because the option was not "expanded" in the dialogue box. Unfortunately I have already created over a dozen drawings with dimensions on the views.
@Toost, Sorry it did not work.
The reason I like to create the points in the modelling side of the drawing file is to make sure that the location of the points is consistent on all the views. It also saves me from creating the points for each of the views.
Quote (Berserk)
Understood. Unfortunately, I don't think there is a way to convert views from the model file to the drawing file after they have been created.
