Undrained and Drained Shear strength for the same clay layer
Hello all,
I have a question (and maybe not the smartest one in the world) that got me confused.
Let’s say there is a normally consolidated clay layer overlain by sand and gravel deposit. There is a dam constructed on top of the sand and gravel deposit. Dam weight introduces excessive pore water pressure into the clay layer. Theoretically, for let’s say slope stability purposes. one should use undrained shear strength for the clay layer.
Where I got a bit confused is the following. Bulbs of pressure coming from the dam are somehow limited to a portion of substratum below the structure. So basically the same clay layer experiences “excessive pore pressure” in vicinity of the structure, but not away from it. Will it make sense to analyze this problem using both drained and undrained shear strength of the clay? Just to clarify this more, please see the attached sketch.
Thank you
Thank you
RE: Undrained and Drained Shear strength for the same clay layer
How different the situation could be if we had overconsolidated clay instead of normally consolidated?
If I remember correctly, overconsolidated clays tend to lose their strength over time and usually drained conditions are more critical to analyze. What if the clay under the dam becomes normally consolidated with undrained conditions being more critical?
How can I combine two portions of the clay layer (overconsolidated away from the dam with drained conditions being more critical and normally consolidated clay underneath the dam with undrained conditions being more critical) in one analysis.
I would also appreciate if you could address my question on overconsolidated clay.
How could two portions of the clay layer (overconsolidated away from the dam with drained conditions being more critical and normally consolidated clay underneath the dam with undrained conditions being more critical) combined together in one analysis.
Thank you once again
Thanks once again,
I really appreciate your time and effort .
Can positive PP generation due to potential dilatant behaviour of the OC clay be good rationale for use of drained (more conservative in this case) rather than undrained strength for OC clay?
f-d
ípapß gordo ainÆt no madre flaca!
