SAP2000-> run is not finished
Hello every one,
i wont to start a pushover analysis with SAP 2000 for RC frame. the run shows that is not finish. what could be the reason for these?
RE: SAP2000-> run is not finished
Is a simple static analysis carried out without problems?
Moreover, are the deformations of a static analysis as expected? Modal analysis can be carried out? These are simple steps to figure our whether something went wrong during drawing and defining the model.
Otherwise, you can check that the force method has been used in the Pushover analysis and not the conjugate one.
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Reifnorcement Design etc.
