API 2000 7tH Edition 2014 Implementation
Dear Expert,i required your support to clarify the implementation of new code API 2000 7tH Edition 2014, The detail of issue is,
Tank Built in date - 1982
The Size of Breather Valve (Pv Valve) 4inch Quntity-01.
As per API 2000 7tH Edition 2014, we verify that for volatile liquids, the out-breathing calculation is simply double,
and calculated Breather valve size is coming 6inch,
Technical query,
I want to know that the API 2000 7tH Edition 2014, is implemented in SABIC existing tanks which have built in before API 2000 7tH Edition 2014.
Technical query,
RE: API 2000 7tH Edition 2014 Implementation
Dejan IVANOVIC
Process Engineer, MSChE
