ETABS Beam/Column and Joint Shear N/A
Good day everyone,
After modelling a 20 stories building I realized that the Beam/Column and Joint Shear are not being checked, instead, it appears "N/A". My columns are defined as Sway Special Frames and all my beams are made of concrete. Can anyone explain me the reason behind this, or give me any tip to look for the root of the problem. I'd sincerely appreciate it.
Thank you.
Thank you.
RE: ETABS Beam/Column and Joint Shear N/A
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Reifnorcement Design etc.
