AWS D1.1 new Clause 9
AWS D1.1 2015 new Clause 9.
Previous versions of D1.1 Table 4.2 (2. Test on Pipe or Tubing). Previous wording was "Nominal Plate, Pipe or Tube Wall Thickness Qualified, in". The new 2015 version reads "Nominal Pipe or Tube Wall Thickness Qualified, in". The word Plate is missing, is this an oversight and is Plate still qualified when a pipe coupon is used?
wp23
wp23
RE: AWS D1.1 new Clause 9
Qualification for connections that utilize plate materials would be qualified in accordance with clause 4.
Best regards - Al
Generally, a plate welded to a tubular is not a tubular connection. Tubular to tubular, i.e., a butt joint, T,K, or Y connections consisting of tubular members, are addressed by Clause 9.
Best regards - Al
